minimum conc. beam size
I am designing a trellis structure. it measures 6x24 in plan view. the top beams in the long direction are supported by columns at 6' o.c. (e.g. 4 typical spans each 6'-0" long.)
this beam will support very light wood trellis on top.
the beam will be cladded with coral rock veneer for a total dimenssion including finish of 12"X8" cross section.
Question:
1. Can the cross section of the beam be 5"X8.5"?
2. what is the minimum beam size allowed by ACI318?
Thanks.
Question:
Thanks.
RE: minimum conc. beam size
but it can be anything smaller by calculations
However I would go at least 6" to give a little more room around the bars.
*.5" high is okay, but you may find it more convient to go 7.5 or 9.5 inches. this would allow you to use 2x8's or 2x10's for side forms.
Good Luck
