H-20 loading for PVC pipe
We are designing a driveway under which we need to put a 12" dia. PVC culvert. Can anyone suggest a website where we can find a table that shows minimum cover for H-10 or H-20 loading, for Sch. 40 PVC or Sch. 80 PVC, etc.?
RE: H-20 loading for PVC pipe
Good luck
"Come to think of it, there are already a million monkeys typing on a million typewriters, and the Usenet is NOTHING like Shakespeare.
Blair Houghton
What I have done in the past is use a pyramid or cone pressure distribution for the wheel load.
Marston and Spangler are the pioneers of the field. You could probably find what you need on the internet.
This link will probably be the answer to your prayers regarding this subject.
http://www.pwpipe.com/pdf/tb-d5.pdf
canman
The website referenced by "canman" is appreciated. I've checked it out, and printed out the technical report for future use.
Thanks to everyone for your advice.
Last page of Chapter 850 gives minimum covers forplastic pipe.
http://www.cpchem.com/docs/EMB2C7.pdf
