Data Conversion Question
<b>Background</b>
I just added a new field Contact_Status_ID to tblContacts
Contact_Status_ID is pulling its value from tblContactStatus
Everything is working fine. I want to write a script which goes into the tblContact and assigns every contact a Contact_Status_ID value = 1  (which is "Active" as seen in Table Model below)
tblContact contains about 20,000 records.
Here is how my code looks while creating a table
CODE
strSQL = "USE database " &_
         "CREATE TABLE database.tblContactSTatus " &_
         "(Contact_Status_ID int IDENTITY NOT NULL, " &_
         "Contact_Status nvarchar(25), "  &_
         "Active bit)"
Response.Write strSQL
Set alterCmd = Server.CreateObject("ADODB.Command")
alterCmd.ActiveConnection = dbconn
alterCmd.CommandText = strSQL
alterCmd.Execute
Set alterCmd = nothing
Response.Write("Done")
tblContactStatus looks like this:
tblContactStatus- Contact_Status_ID -int -
tblContactStatus- Contact_Status -  nvarchar -
tblContactStatus- Active - bit -
tblContact looks like this
tblContacts - Contact_ID - int -
tblContacts - Last_Name - - nvarchar -
tblContacts - First_Name - - nvarchar -
tblContacts - Contact_Status_ID - - int -
Data Model for tblContactStatus
Contact_Status_ID    Contact_Status     Active
   1                    Active             1
   2                    Non-Active         1
   3                    Just-In-Time       1
