diferent vibration values over time - further data
I checked a ventilator (100 kw - 960rpm) and obtained different values of vibration. Values go from 4 mm/s to 11 mm/s. The ventilator has 8 blades (2*4 blades, two on 0º, two on 90º, two on 180º and two more on 270º)
The spectrum returns only a peak near 64Hz which i presume to be from the blades (960 / 60 * 4 = 64 Hz) Actually, this peak goes from 4 to 11 mm/s in separate measures.
I do not understand. Nothing changed between the measures.
I can guarantee that there is nothing wrong with the data collector and probes.
Actually, There were two fans on site, they are exactly the same (axial flow fan). One of them is ok (rms 3 to 5mm/s) and the other has symptoms like the one i described.
The inlet flow is not varying on any of them.
However, with a close inspection i found that the blades on this fan were slightly bended on one end (the blades on the other fan were not bended) and that a small part of one blade was missing.
Could this be the reason? The bended ends are enough to make this happen?
Thank you for any help.
RE: diferent vibration values over time - further data
You need to secure the fan and give it a thorough inspection.
