Pressure Differential btw Potable and Recycled Mains
Hi All,
Just wondering if anyone is using pressure diffentials in their design of dual reticulation systems (ie maintain a higher pressure in the potable main than recycled main) so as to minimise risk of cross contamination in the event of accidental cross connections. Im referring to large scale residential water distribution systems when i refer to dual reticulation. Any comments/information would ne appreciated.
Cheers
Mark
Cheers
Mark
RE: Pressure Differential btw Potable and Recycled Mains
I don't think pressure differential is on the list of approved backflow prevention systems or schemes. On the surface this may sound like a good idea, but you have to remember when you have a pressurized system transients can and will be generated. The transients can cause systems to go to extreme vacuums without any control of the system operators, negating any beneficial positive pressures you maintain.
I have designed a few reclaim systems and we do usually design them for lower pressures to increase cost savings. The sale of the water is with the understanding that the customer is to supply pressures they will need and that the system only capable of supplying adequate suction pressures to the customers system.
Let us know what you are planning there and maybe we can help more..
BobPE
Hyper Dictionary
English Dictionary Computer Dictionary Thesaurus Dream Dictionary Medical Dictionary
Search Dictionary:
Meaning of RETICULATION
Pronunciation: ri`tikyu'leyshun
WordNet Dictionary
Definition:
1. [n] an interconnected or intersecting configuration or system of components; "there was a hole in the network where some of the strands were broken"; "he used a copper frame with copper meshing"
2. [n] (photography) the formation of a network of cracks or wrinkles in a photographic emulsion
Websites:
* Find the Best Sites For Reticulation With Starware
Starware search is an excellent resource for quality sites on Reticulation and much more! Starware also provides related listings for Reticulation.
search.starware.com
Synonyms: mesh, meshing, meshwork, net, network
See Also: computer network, early warning system, formation, graticule, grid, reference grid, reseau, reticle, reticule, system
Webster's 1913 Dictionary
Definition:
\Re*tic`u*la"tion\, n.
The quality or state of being reticulated, or netlike; that
which is reticulated; network; an organization resembling a
net.
The particular net you occupy in the great
reticulation. --Carlyle.
COPYRIGHT © 2000-2003 WEBNOX CORP. HOME | ABOUT HYPERDICTIONARY
