Heat treating of aluminum wire and cold headed rivets
I have a couple of quick questions. First, are aluminum rivets always cold headed from strain hardened wire, e.g. 2117-H13 or 7050-H13 or is the wire supplied in the fully annealed condition? Second, for rivets that are to be supplied in the artificially aged condition, is a solution heat treatment always performed after cold heading, or is it possible that the wire is annealed, the rivet is formed, and then the rivet is artificially aged? I understand that various aerospace product standards specify the heat treatment of the final product (rivet), but I am not totally clear on the incoming wire.
RE: Heat treating of aluminum wire and cold headed rivets
Did you post this same question in the Aerospace engineering forum?
Basics. for aerospace rivets...
1. The basic procurement spec for aluminum driven rivets [NASM5674] describes all aspects of the finished rivet... and certain mandatory processes such as heat treatment and finishing... but does NOT describe exactly how-to-get-there-from-here.
2. Aluminum wire material is QQ-A-430 [or possibly ASTM B316]. The rivet wire spec[s] is[are] titled "Aluminum Alloy Rod and Wire: for Rivets and Cold Heading". This material is useful for a wide variety of cold headed parts, of which rivets are only a specific/limited application [note that various alloys are also included in the specs, which have never-been used for rivets]. In-general...
2.1 The alloys are provided in "-O" temper and "-Hxx" [strain hardened] conditions... which are NEVER used in final parts... except for non-heat treated alloys [generally limited to 1100 "A" rivets].
2.2 The annealed wire/rods are used for various cold headed products and probably larger diameter rivets.
2.3 Cold working is used to improve roundness, smoothness, straightness, etc... of fine-rod or wire wire, and would result in mild % strain hardenening [noted by the low "-H13" number]. The MOST LIKELY need for these characteristics is to improve "feeding" thru automated fabrication equipment, allowing hundreds-of-thousands of finished parts to be made at a blindingly-rapid pace. The improve stiffness and control of wire dimensions [roundness smoothenss, etc] facilitates this processing: whereas dead soft [annealed] "as-extruded" wire and rod would most-likely "gum-up" the processing equipment... or require significantly slower processing to avoid feeding problems.
3. After forming, ALL of the [heat-treatable] "raw" rivets are heat-treated to final temper per AMS2770... which would remove all affects of the strain hardening, except for grain flow characteristics [easily exposed by metallurgical cross-section and analysis, if needed].
Regards, Wil Taylor
