Modifying Extruded Surfaces
All,
Am stuck in modifying an extruded suface in 3D microstation.  I have created surface using smartline and then extruded using the tools.  Now, I find that I need to have a blockout in that extrusion (3D) and can't seem to figure out how to do it.  Most examples have such simple extrusions that they're not applicable and are of no help and the help menu is no very user friendly.
I appreciate all help/comments.
Qshake
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
RE: Modifying Extruded Surfaces
MS/J will not do what you want. For manipulation of existing surfaces, you need to have Triforma on top of Microstation.
HTH
