Solvent for Ethylene-Propylene-Diene-Monomer
HI,
Are their any other solvents apart from Toulene, for Ethylene-Propylene-Diene-Monomer (EPDM).
Thanks in advance.
Sreedhar.
RE: Solvent for Ethylene-Propylene-Diene-Monomer
If you go to http://www.coleparmer.com/techinfo/ChemComp.asp, use EPDM for the material and D-Severe Effect for the Compatibility Level, you will find a slew of chemicals that attack EPDM.  Perhaps one on this list will help you.
Just about any petroleum product (oils, solvents, fuels) will dissolve EPDM.
