Create an arc tangent to a line thru a point
I am a fairly new user to unigraphics so this is probably something simple, how you create an arc tangent to a line thru a point
Example going from left to right you have 1.00 horizontal line, at the end point of this line you have a .25 vertical line I want to create a
1.00 radius tangent to the 1.00 horizontle line thru the top of the .250 vertical line
RE: Create an arc tangent to a line thru a point
Fillet option as discribed by cowski is a good method also but if you can use basic curves for a quick way to get the geometry and add to sketch I've found this helpfull using a combination of Basic Curves and Sketcher.
Michael
