Constraining a detail view callout
Does anybody know of a way to constrain a detail veiw callout to a particualar area on an assembly drawing. My problem is this, i have an assembly driven by a design table and a detail view of a part on that assembly. If i replace a part in the assembly that causes the assembly to change in length and thus move the location of the part i'm detailing, the detail view will not move with that particular part, it stays at the location on the sheet were it was created. I'm running V5R13 P1
Mark
Mark
RE: Constraining a detail view callout
Right button on your detailed view and select View positioning. There you can break the link with the mother view (Position Independly of Reference View) or set a a relative position.
-Hora
The actual view isn't the problem, being a detail view it's position on the sheet isn't linked to the mother view, unlike projection views. My problem is with the callout for the detail view on the mother view. I can't find a way for it to stay put on what i want to detail when i change the parts in the assembly via a design table, which in turn change the length of my assembly. Thanks in advance for any help you can give me.
Mark
Sorry, I missunderstood your problem. Did you fix the first component in your assembly? Maybe here is the problem.
-Hora.
mark
Thanks for your patience hora.
Mark
(it's friday, and i'm heading home! ow my head)
