Template Drawing and AutoCAD
Im new at solid works.
How can I import a AutoCAD drawing (.DWG) into a template drawing(.SLDDRW) that I all ready have?
RE: Template Drawing and AutoCAD
Or are you trying to setup new sheet formats?
Scott Baugh, CSWP
ctopher (Mechanical)
File, open, files of type ".dwg", browse to file. Follow steps.
macduff (Mechanical)
Scott,
Can anyone help me on this?
jmongan (Mechanical)
Open a SW template, go to edit sheet format mode, open your ACAD template, select all, copy, go to SW, paste.
SBaugh (Mechanical)
jmongan is right, just highlight the Block and click Edit/Cut cut the Title block, RMB the sheet and select Edit Sheet format, and paste the title block (FYI - pick the sheet before pasting).
Thanks for your help guys!
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
How do I import a dwg title block and make it a SW template?
I open the file in SW and tried to save it as a "drwdot" but I can't toggle between "edit sheet" and "edit sheet format". All I get is the geometry on the top and when toggled to "edit sheet", everything goes blank.
Macduff
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
You will have to do some clean up and positioning etc, but to me that is the easiest way to get anything autocad into SW. Good old copy and paste.
Scott Baugh, CSWP
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
