Rubber bladder, hand inflatable
I am looking for a "rubber" tube, about 1/8" to 1/4" diameter that can be inflated manually, using a pump similar to the one on a blood pressure cuff.  It needs to expand with air or maybe even hydralic pressure in the future. It could ideally double in width, but does not necessarily have to expand that much. Most of the tubes I have found have an outside diameter too great to be expanded or inflated by hand.
This tube, needs to be about 10 feet long, or maybe even longer, and needs to expand evenly or relatively evenly along the entire length.
Thanks for your help.
