testing of AEI synchronous mtr
I  wish to test an electric motor on a dynamometer facility.   The motor is
3 Phase Vertical Synchronous Induction Motor with Top mounted Exciter (with interpoles VAX control).  The motor uses liquid resistance starters for induction motor starting and uses 6.6KV CT's to supply a DC rectifier which in turn feeds DC to the Field windings.  How do i go abouts testing this motor. The motor details are:
Motor Make: AEI  Ltd
Type:             Synchronous Induction
Frame Size: TAVW 168132
Power:            525 HP (361.8kW)
Speed:            333rpm
Voltage:    6600V
