VBA For AutoCAD Inquiry
Hello all,
Is it possible to create an Unnammed group using VBA??  The way the syntax is, it seems that you must name the group.  I know you can do it in AutoLISP, and as well at the command prompt.
thanks
DRW75
RE: VBA For AutoCAD Inquiry
The Visual Basic Customization discussion group can be accessed in either of the following ways:
By NNTP discussion group reader at
news://discussion.autodesk.com/autodesk.autocad.customization.vba
By HTTP (web-based) interface at
http://discussion.autodesk.com/forum.jspa?forumID=33
Tracy Lincoln, TLConsulting http://tlconsulting.blogspot.com
Consulting, Design & Training Specialist
Autodesk Discussion Group Facilitator
Discussion Group Index: http://discussion.autodesk.com
Thanks for the reference!
I'm on the way to an answer!
thanks
DRW75
