SECTION VIEWS
SECTION VIEWS
SECTION VIEWS
Some trouble with creating a section view, I have modelled a turbine wheel and that after some time was successful. however I'm now working on the drawing side of it, and when creating views I cant seam to get a section I have the first section which is fine, but the second section doesn't work right the section cut line changes to a brown and the view is a solid, the error message says nothing????
ta James
RE: SECTION VIEWS
Strange, if i offset the section cut line from the origin it's fine?
RE: SECTION VIEWS
ctopher (Mechanical)
I just updated to SP5.0 (2004) and started having the same problem after the update. James78, what version/SP do you have?
