heat transfer to a thin cylinder rod
Dear friends,
I would to like to know how to calculate the heat transfer to a cylinder rod during the quencing process after the rod is being heated to 850 degress Celcius.
Thanks.
Thanks.
RE: heat transfer to a thin cylinder rod
Water, air, oil. Temp and flow of quenching fluid.
Look up "Heisler Chart" in the Index
Itis heated upto 850 degrees Celcius and sprayed with water(20 degrees Celcius) at the bottom of the cylinder(quenching process).
How to determine the cooling rate at the centre of this cylinder?
Should I consider the heat tranfer of the rod to air and water separately for the two dimensional heat flow?
How to determine the Biot Number?Should I consider two Biot Numbers, one is for air and the other one is for water?
You can always look up standard quench hardnening curves for a good estimate.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
FOR THIS 2D TRANSIENT, YES.
I WOULD CONSIDER HEAT TRANS COEF FOR BOTH AIR AND WATER.
THIS CAN BE MESSY- ESPECIALLY WITH NATURAL CONVECTION AND RADIATION FOR THE AIR SURFACE.
