tube and sheet heat exchanger
Dear friends,
I would like to know the way to design a simple tube and sheet heat exchanger.
Thanks.
Thanks.
RE: tube and sheet heat exchanger
http://www.wlv.com/products/databook/
athomas236
Transfering heat from what to what?
What exactly are you asking?
I actually think that your post should be red flagged due to the lack of information you provide compared to the amount that you are asking for.
The tentative sizing routine found as the first calculation form on http://www.engineeringpage.com/nav/he.html will give you a simle way to get an idea of the area needed.
If you feel like doing the full calculation, use the thermal rating routine after that.
Best Regards, Wim
