getlogin in C programming
I am trying to get the login name of the user in C programming .After searching in web i found the Miscellaneous function getlogin() in unistd.h.I am using VC++ compiler .
This header file is not available in VC++.Please guide me how to solve this issue or tell me how to get the login information of the user.
regards,
KarthikJ
regards,
KarthikJ
RE: getlogin in C programming
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
