Air handling unit smoke dampers
I have a new air handler and exhast fan serving 3 floor of production area. The air handelr is located on the top floor and serves each floor via a masonary shaft. The consultant wants smoke dampers on each floor take off so that on fire mode the air handler shuts down and the smoke dampers close. I think this is fine.
However he also wants smoke dampers on the discharge side of the air handler and on the intake of the fan to do the same. I dont know why these are required. Only 20ft away from the air handler and fan the floor smoke dampers exist and will cloe anyway. There is no take off between the air handlier and the first set of floor smoke damper. Is this a waste, can I delete them?
RE: Air handling unit smoke dampers
It seems to me that the Uniform Mechanical Code is similar but I can't remember off the top of my head.
Chapter 51 Fire and Smoke Management -ASHRAE 98 may helps...
