First angle projection
I need to make drawings with a first angle projected view.  That part is simple enough.  What I can't fine is the first angle projection symbol so I can mark my drawings as such.  Any thoughts.
RE: First angle projection
Draw one?
Yep, draw one.  That's what I did for 3rd angle projection.
"Customer satisfaction, while theoretically possible, is neither guaranteed nor statistically likely.--E.L. Kersten
http://www.EsoxRepublic.com
Yeah, thats what I did.  I was hoping for one provided.
Hey guys,
All you have to do is RMB on your drawing sheet select properties then select the First Angle Projection radio button. All views for that sheet will be first angle projection.
Hope this helps!
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
