ANSYS 8.0 workbench material files
Has anyone succesfully added their own material files to the .XML library Workbench uses? Could I get a dummy copy (you can remove all the data, just leave placeholders please)? I can't get the format correct, the original files only have temperature dependent fatigue properties and I want to add temp dependent alphas, E's, etc. Thanks in advance!
RE: ANSYS 8.0 workbench material files
