Transferring 13% Sodium Hypochlorite
I need to transfer a 13% solution of sodium hypochlorite ~ 400' from a large storage tank to a smaller day tank at 25gpm (with only ~13.5' TDH). I have contacted companies such as Prominent (whose metering pumps we will use for the hypo injection), but for larger flow rate they do not recommend a metering pump and could offer no advice. Could anyone recommend a pump for this type of application? Also how should degassing be handled with this type of system?
RE: Transferring 13% Sodium Hypochlorite
