cryogenic pump
cryogenic pump
I search a little pump (1l/min, less than 10m of HMT) to empty a tank that contain cryogenic liquid (butane, pentane, etc) at low température (-160°C). The ideal pump is to work without electricity but with N2 flow to avoid explosion problems.
Do someone know a fabricant of this type of pump.
Thank you
Thank you
RE: cryogenic pump
Our pumps are driven by an electromotor. When you use N2 sealgas on the shaftseal and sealgas (N2) on the motor there is no risk.
If you search on Google with searchkey "Sefco pumps" you'll find the website.
Cryotechnic
RE: cryogenic pump
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
