Finding a radius smaller than x.xx
Is their a way in UG NX2 to find a radius smaller than X.XX in the modeling side.
Jeremy
Jeremy
RE: Finding a radius smaller than x.xx
Set Radius Type to Minimum; Display Type to Fringe. Select your entire part & set your Display Surface Resolution then Apply. Click Reset Data Range & use the sliders to get the Middle value as close as possible to your minimum radius value. I believe sliding them all the way to the left will show the minimum radius values. Use the scale that appears in the graphics window.
Keep in mind, this is an analysis & doesn't always give exact results.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Keith Young
keith.a.young@comcast.net
Walway Enterprises
UG Tool Design
