Single ended 50MHz sine to square wave
We need to convert a 50MHz sinewave (maybe 1Vpp) from a built in synthesizer to a 3.3 V clock signal to be used in our logic on another board in the other end of the box.
The 50MHz sine will most likely come in a shielded coax cable with ground.
We 1st thought about using a comparator, but we havn't found any yet, that is fast enough and available. Besides it will require some external components for biasing etc.
Line receivers, on the other hand, do most of this, are available, and plenty fast enough.
I have found DS90LV018A (National) from one of our suppliers, but the data sheet says, I should not connect any of the two inputs to a fixed voltage, as the device then will go into some fail-safe mode.
Or have I misunderstood something here.
Can I connect one input to, say, 1.5V and the other to my 50MHz source ?
I will still have to provide some external bias and termination, but we will be up and running.
Are there other solutions?
RE: Single ended 50MHz sine to square wave
I used a 30 MHz component, but there are transformers available for more than 200 MHz. Look at Fair-Rite, minicircuits or do a generic search for "broadband transformer" on google.
Also, look at 'zero crossing detectors'.
With respect to moving the reference around, it is quite easy when you're dealing with 50 MHz because you can use resistors to set the DC level and then couple in the 50 MHz through a small value capacitor.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
Do they work for 3.3V logic as well ?
I know practically nothing about ECL, besides from its excistence, and that it involves -2V
Most likely it has 3.3 V version, too.
read FAQ240-1032
http://www
TTFN
parts (bias resistors, C cupling and back-to back shottkies
to limit the input ) And it is not cheap...
read FAQ240-1032
http://www.linear-tech.com/pc/categoryProducts.do
read FAQ240-1032
If you use a Pulse Engineering 55 MHz transformer and bias the low side of the secondary about 0.5 V below your logic threshold then you have galvanic isolation and you need no other circuit than a spare logic gate to convert the sine to a square. The isolation reduces interference so that a schmitt trigger isn't needed.
Costly? Depends on volume. Five dollars for one off. But no other problems. And, as I said, the galvanic isolation could be gold if you want to go between boards.
We used it for 10MHz clock years back.
They are good for at least 180 MHz (-1dB) and can deliver 1:2 ratios, so ....
