Projection area
Projection area
If I have solid part, how can find the area of it's projection to a plane? I cannot figure out how to project soid
Thank you
Thank you
RE: Projection area
* Go to the sketcher workbench (selecting the plane on which you want the projection).
* Project the surface under consideration using Project 3d element command
* The resultant must be a closed polygon
* Now go to GSD workbench ans create a FILL for the polygon.
* Now Using 'Measure Item' Command, you can get the area.
RE: Projection area
The Method is lengthy, but it works
