Drawings in Excel
Drawings in Excel
Does anybody know how to create a drawing or sketch in Excel which is dynamically driven by values in the spreadsheet? In other words, if I have a spreadsheet which designs a certain component, is it possible to create a sketch of that component within excel where the dimensions of the component are changed in real time based upon what the user enters?
Chris
Chris
RE: Drawings in Excel
Now you want a spreadsheet to be a parametric CAD program.
Link your Excel spreadsheet with your CAD program. Its probably already been done by somebody.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
I have done some small experiments with the X-Y scatter plot, and this seems like a good and simple solution. I'm assuming I can also place text and autoshapes on the chart, but I haven't figured this part out yet.
=$a$1
for example
here's a link to smartsketch that should work.
ppm.intergraph.com/smartsketch
http://www.structural-engineering.fsnet.co.uk/
and follow the links to "Spreadsheets". Download the application called "PlanSketch". This is a very clever spreadsheet which allows you to enter a table of column and beam locations and sizes, including floor penetrations etc, and produces a scaled drawing of the resulting floor layout. You might be able to examine the coding to see how it is done.
Hope this helps!
Line, Polyline, Rectangle, Curve, etc.
Here are some examples:
CODE
Dim triArray(1 To 4, 1 To 2) As Single
triArray(1, 1) = 25 'Assign values in code, Or
triArray(1, 2) = 100 'Read a table of values in the sheet
triArray(2, 1) = 100
triArray(2, 2) = 150
triArray(3, 1) = 150
triArray(3, 2) = 50
triArray(4, 1) = 25 ' Last point has same coordinates as first
triArray(4, 2) = 90 ' else not filled as a solid
Set myDocument = Worksheets(1)
myDocument.Shapes.AddPolyline triArray
With myDocument.Shapes.AddLine(10, 10, 250, 250).Line
.DashStyle = msoLineDashDotDot
.ForeColor.RGB = RGB(50, 0, 128)
End With
With myDocument.Shapes.AddShape(msoShapeRectangle, 144, 144, 72, 72)
.Name = "Red Square"
.Fill.ForeColor.RGB = RGB(255, 0, 0)
.Line.DashStyle = msoLineDashDot
End With
End Sub
