Uhhhh O! Is this Unobtainium?
Does anyone have a source for:
SAE J404 4340 -- .236x1.125x[bold]COIL[/bold] annealed
OR
SAE J404 4130 -- .236x1.125x[bold]COIL[/bold] annealed
(This is to run in a stamping press, must be coil.)
OR
RE: Uhhhh O! Is this Unobtainium?
ht
http://w
http://www.samuel.com
At that thickness it might be tough to find cold rolled, that is a hot rolled gage for most people.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Profile might work, they also may be able to help with the interesting profile this part has.
(stars round)
nick
"...is applicable to billets, blooms, slabs, plates, wire rods, and hot-rolled and cold-finished bars.
SAE J404 is not applicable to the following product forms:
a. Structural shapes - Not normally furnished to alloy chemistries
b. Sheet and strip, hot-rolled and cold-rolled - Refer to ASTM A 506 and A 507
c. Seamless and welded mechanical tubing - Refer to ASTM A 513 and A 519
I second unclesyd's recommendation.
Cory
Thx again.
Another source for shaped wire that you may want to investigate is Contours (part of Bekaert):
http://www.contours.com/index.cfm
