?Tester to tell if magnetic or electronic ballast?
Is there a tester available (similar to foot candles tester) to tell if a flourescent lamp is on a magnetic or electronic ballast? If you would let me know who manufactures this type of device and a website address it would be a real help.
Thank you for your assistance.
RE: ?Tester to tell if magnetic or electronic ballast?
rbulsara
I have done a job with 40,000 fixtures some ballasts were missed. All the lamps were changed. My subcontractor missed them.
I need a faster way then check each one. I have seen this type of device I just need to find the manufacturer.
To verify which type of ballast is currently installed in a given fixture, without having to take it apart, a flicker checker is available through Motorola (call 1-800-453-1506 for information on obtaining this inexpensive tool, known as a flicker checker device [FCD]). Spin the flicker checker on a flat surface underneath the fluorescent lamp in question. If the ballast is the older, electro-magnetic type, you will see a stroboscopic effect appear as it spins. If the fixture has the high-frequency, electronic type ballast, you will see no effect on the flicker checker
Enjoy the toy
pennpoint
when pointed at the fixture the old magnetic balast will
indicate 60 Hz.
