File/Properties------Comments Text does not center align!
When you type something in the "comments" text field ( File/Properties) of a part/assembly document, it used to center align itself in the text box that we link it to in the drawing template. ( Lets say you have a comments text box in your drawing template linked to this comments from the part/assembly.)
Now it doesnt do it in SW 2005. Well the first line centers itself in the box but the subsequent 2nd or 3rd lines are left aligned respective to the first line unless you manually keep spacing these out for each and every line and drawing you create. Did anyone else face this? Is there a way we could fix this?
RE: File/Properties------Comments Text does not center align!
You might need to create a new template with the text in notes or other fields set to centered.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
