Default Parameters
Default Parameters
Dear friends,
Can anyone give me a list of the default parameters used in Pro/E Modeling, Drawing etc.(cur_row, hole_number etc.)
Thanks in advance
Please reply even if you that something like this exists.
Thanks in advance
Amish Bhushan Goel
Engineer
Hitech e Soft
amg@hitechesoft.com
RE: Default Parameters
On your Pro/E documentation CD, you can browse the CD and look for PDF files. There are several, and you need to look for once called CONFIGFILEOPTIONS.PDF
Every single config option is here, and each one's possible values are listed with descriptions/explanations of their use. Among the values, there will be one in italics - this is the default value, and remains set until the config.pro/config.sup file specifies otherwise.
If this is what you want, but don't have the documentation CD, email me and I can reply with the PDF file attached.
spencer.smith@iwkabi.com
Recneps
I will be greateful to you if you send me the PDF files you are mentioning.
Thanks for your response.
Amish Bhushan Goel
Engineer
Hitech e Soft
amg@hitechesoft.com
http://utopia.knoware.nl/~ocorten/UTIL/view_config.html
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
717-532-9181
ben_loosli@irco.com
for config.pro help.
