1,2,3-perspective and cabinet projection
Hey,
I'm really new to autocad and just started to pick up the basics. The one thing I couldn't find was how to create from existing model:
* two-point perspective (xy perspective)
* three-point perspective (xyz perspective)
The real perspective that autocad uses is the one-point perspective (railroad closes at horizon).
Second thing I was unable to find was how to make cabinet projection - angle between xy axis 90 and between yz, xz 135 degrees. How can I change projection angles between axis.
I'm just hoping these things can be done with autocad because I'm have to show my works on friday :)
Thanks in advance,
Taavi
Thanks in advance,
Taavi
RE: 1,2,3-perspective and cabinet projection
If you are drawing them yourself, draw in 3D or turn on the UCS toolbar expriment with some buttons and draw in Isometric.
I like 3D better.
Also, get a book or take a classs if possible
Hope this helps,
John
Posted here on Eng-Tips,
http://www.cadtutor.net/forum/viewtopic.php?t=2162
http://dis
Answers were provided and not even one Thank You? Wow?
