bolt and weld connections
what is the comparative cost of field and shop erections of bolt and weld connections?
RE: bolt and weld connections
Welders are typically more expensive per hour than your average construction worker, and welding takes longer than bolting.
On the other hand, welded connections are better where deflections under dead load might mean bolt holes won't line up (crossframes in curved or skewed members), or where the connection is hard to match exactly (like splicing rolled sections where mill tolerances lead to thickness differences or nonalignment of flange & web). If the splice will be architecturally exposed, welded might be considered to be more aesthetic at a distance.
You want comparison of field vs. shop, or bolted vs. welded? Bridge or building application, or doesn't it matter?
Hg
you have been more than helpful. i appreciate your responses very much. thank-you once yet again....
Hg
