Case Statement
Case Statement
Case Statement
Currently, having problems with a case statement. Case 265 and Case 229 are not sending out the correct values. Do I need a Case to statement to correct this? Any and all help will be appreciated.
Sub LandDrill(ToolDiameter, Flutes, TolPlus, TolMinus, FluteStyle)
         Select Case FluteStyle
            Case 204
                Select Case ToolDiameter
                    Case Is < 0.2499
                        TolPlus = 0.5 * ToolDiameter
                        TolMinus = 0.6 * ToolDiameter
                    Case Else
                        TolPlus = 0.55 * ToolDiameter
                End Select
            Case 212
                    Case Is < 0.2499
                    Case Else
                End Select
            Case 265
                    TolPlus = 0.66 * ToolDiameter
                    TolMinus = 0.74 * ToolDiameter
            Case 229
                    TolPlus = 0.15 * ToolDiameter
                    TolMinus = 0.2 * ToolDiameter
        Case Else
        End Select
End Sub
RE: Case Statement
What happens if you move those case statements up to the top of the function?
RE: Case Statement
No luck on moving the 229 and 265 statement to the top. Pulls hair out
RE: Case Statement
When you feed in 229 or 265, which section of code appears to be executed?
Perhaps you should ensure that the FluteStyle argument is either of type Integer or of type Long.
RE: Case Statement
Is FluteStyle an integer? Is it part of an enumeration? Are you sure the value of 229 or 265 is being passed into the Sub? Can any other procedure change the value of FluteStyle (or any other variable used in LandDrill) before calling Sub LandDrill (I notice it is passed by ref - the default if not specified by val).
Two things I would try: put the case numbers in ascending order and eliminate the nested select case statements. I can't guarantee this will help, it's just what I'd try.
CODE
        Case 204
            If ToolDiameter < 0.2499
            Else
            End If
        Case 212
            Else
            End If
        Case 229
        Case 265
        Case Else
        End Select
End Sub
RE: Case Statement
It may depend on which version of Excel you're using. I seem to recall that some older versions require that Select Case statements with numeric arguments need to be in numeric order, although that isn't the case now (XP)
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
RE: Case Statement
Nice pun, johnwm.
RE: Case Statement
I'd feed it a value, then step through the function in VB, looking at values.  Does it work in the VB editor environment but not the spreadsheet?
