synchronous buck converter
I am trying to develop a circuit to convert 5-18Vdc, 100ma max to 0.4Vdc, 400ma. I am working on a synchronous buck converter design but I am finding limited resources on a discrete design. All of the buck converter IC's I found do not go low enough and have inadequate efficiency when they are even close. I have been toying with the idea of using the basic synchronous converter with a P and N channel fet. The problem is that I am trying to use a MSP430 microcontroller to drive the circuit. What would you reccomend for a gate driver for the upper P-channel fet? If you any other suggestions please put them in too.
RE: synchronous buck converter
I like that idea, I'll have to look at that one. Efficiency is of great concern so I will have to see if that will work.
felixc,
I haven't seen a problem yet with "shoot through" or efficiency. I have the PWM code already written and put in a delay between switching each seperate gate drive.
The problem I am dealing with the most is that the microcontroller I am using is a 3V logic high and I can't drive the gates with that, especially the P-channel FET.
Thanks for the input so far.
