Help on Pipe fitting solutions for solidworks
I have been an AutoCad user for years. A year ago my company purchased an AutoCAD add-on called Mech-Q pipe. This add on gives you a number of fittings (in 2d & 3d) welded, threaded, etc .... elbows, flanges, tees, threadolets, etc... My company is thinking of making the jump to SW. I've poked around the web and get the feeling that SW-Piping does not have the best fittings library...
Is this true? Are there other SW options for pipe fittings. Add-ons made by other developers? Online library?
RE: Help on Pipe fitting solutions for solidworks
You can Download other peoples files from the web too. check out the FAQ on websites. Also check out www.3dcpntectcentral.com and if you have access to the SW website (through Subscription Support) there are other models there too on Piping.
I used it before it was routing and I liked it for the short time I used it.
Scott Baugh, CSWP
MadMango (Mechanical)
TYPO: that's www.3dcontentcentral.com
SBaugh (Mechanical)
Thanks MM! I done that at 3:00 am this morning.
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Scott Baugh, CSWP
CorBlimeyLimey (Mechanical)
There's a 3:00 in the morning too
GasDistEng (Mechanical)
Thanks Sbaugh-
ctopher (Mechanical)
GasDistEng,
crjones (Mechanical)
You might try CADRegister.com, it's part of the Thomas Register.
StiLLiving (Industrial)
Not the library, but capable CAD system - this is what you are looking for. Since your company already purchased AutoCAD add-in (fittings library), SW can easily take it too. No sweat.
Merry Christmas
Is the link that you posted correct? I can't get to that site.
MadMango retyped it
www.3dcontentcentral.com is a good site too as mentioned above.
Cheers
