Where can i find the algorithms I need to do this...
I am creating a neural network using sound as input, I need several algorithms to make the sound file manageable.
i need to rectify the signal, then use some kind of envelope/filter to reduce the complexity and vastly reduce the inputs, then finally I need to detect a starting point in the file to remove the unnecessary silennce.  I was thinking that anything below a certain dB would be chopped off from the beginning.
Does anyone know where I can find these,, or find out info on these so I can write them myself?
RE: Where can i find the algorithms I need to do this...
FWIW Here is the first one
rectified_signal = abs(signal)
M
Dr Michael F Platten
