ANSYS on dual-processor machine ???
Hi
Does ANSYS make use of dual-processor machines ?
I am asking about both versions - for UNIX/Linux and MS Windows 2k/XP....
Thanks !
Best Regards,
RSth
RE: ANSYS on dual-processor machine ???
LS-DYNA most definitely will make use of both CPUs (as long as you specify in the keyfile). The implicit ANSYS package is (1) license dependent (as an "add-on" package) and (2) solver dependent (see help file on the parallel processing guide) and can be activated by issuing /CON,NPROC,2. If you issue this command with all ANSYS defaults you will still only have access to one CPU. Same applies for windows/linux/unix machines I believe.
Cheers,
-- drej --
