High Temp Alloy
High Temp Alloy
I am making a high temperature furnace liner that will house fused silica tubes. This is necessary as the glass tubes can sometimes blow up. The furnace will operate at a maximum of 1000 deg C and be slow cooled (1-5 deg C/hr) to room temperature. We are going to flow an argon atmosphere over the metal liner to minimize oxidation.
We are currently looking at Inconel alloy 601 and 617 as well as Udimet alloy L-605. From what I understand these Cr containing alloys have a tendency to sensitize in the temperature range we operate. Will sensitization significantly alter the integrity and mechanical properties of the alloy?
If so are there any other suggestions for the liner material?
RE: High Temp Alloy
If I understand your operation this will be a near static temperature, no cycling. This is important. 601 has better resistance in cyclic conditions, 600 is just as good in static.
If you want a top end alloy to look at consider 214. Though I doubt that you need it.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
RE: High Temp Alloy
http://www.specialmetals.com/products/
The Technical Bulletins are very comprehensive and will provide you the necessary information for optimizing your alloy selection. The Inconel 601 in the solution treated condition sounds like your best bet.
The Haynes International web site below has other high temperature alloys for consideration;
http://www.haynesintl.com/
RE: High Temp Alloy
RE: High Temp Alloy
RE: High Temp Alloy
If you have a pure argon atmosphere on one side of the metal, what is on the other side?
These alloys don't sensitize in the way common stainless does, they don't form CrC in the grain boundaries. They form all sorts of complex mixed metal carbides and intermetallic phases. It isn't a big deal with these alloys. This is what they are designed to do.
RE: High Temp Alloy
RE: High Temp Alloy
The ultimate failure of this liner will be from grain growth and creap.
You really want it as light weight as possible. It may distort a lot, but the stresses will be much lower. Let it warp and don't straighten it out.
RE: High Temp Alloy
Just for your knowledge, Ar will be inside the container too. The only other substances the metal will come in contact with are silica tubes on the inside and alumina tube on the outside.
RE: High Temp Alloy
RE: High Temp Alloy
Alloy 602 CA is a step up from 601 due to its higher chromium and aluminum and would be comparable to Haynes 230 at 1000C.
Oxidation testing can be found in the high temperature alloy brochure in the technical resource center of Rolled Alloys. It covers oxidation testing for alloys ranging from 309 to high nickel alloys at temperatures from 1600F to 2200F.
http://www.rolledalloys.com
