Model Response with Ideas MS 8.0
I used the version 7 to made the FRF fuction with the following procedure:
Model Response
Response Evaluation
Damping ratios Viscous 0.015
ALL
CResponse Set Create Phisical DOF
                                             Node
                                                   Select DOF direction
Evaluate FRF
              acceleration
               xmin, xmax ( frequency range )
                number of evaluation intervals
                  excitation DOF
                    phisical
                    direction
Does someone know how make the same with version 8 ?
Many thank
Andrea Mino
