Orthotropic material setting CatiaV5
Hello.
I am trying to run a FEA in CatiaV5R13 on a wood peice using the orthotropic material setting in the material properties. When running the analysis, I always get the "invalid material caracteristic" error message even thought the input values are well known and correct. Is there a secret Catia move that must be done so it works ? Even in the Help Files tutorial, there is no reference on orthotropic material setting. If I use the isothropic material setting it works but the values are way off from a wood ptototype I test benched.
Thanks in advance
Lofo
Thanks in advance
Lofo
RE: Orthotropic material setting CatiaV5
Young length/w 11200MPA
Young transv. 600MPA
Poisson: 0.45
Shear XY: 6MPA
Shear XZ: 6MPA
Shear YZ: 50MPA
Mass: 420kg m3
Tensile length/W 45MPA
Compres. length/W 30MPA
Tensile transv. 1,8MPA
Compres. transv. 3MPA
Thermal exp. lenght/W 0.00000002
Thermal exp. transv. 0.00000001
Lofo
