Converting to PDF
Converting to PDF
Is there a way to batch convert drawings to PDF files.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Converting to PDF
Otherwise, place an Enhancement request into SW. Too add it to Task Scheduler, but you will need at least the Office package to get TS.
Scott Baugh, CSWP
CorBlimeyLimey (Mechanical)
See your original Thread559-109356
SBaugh (Mechanical)
That's too funny when you click that thread link.
3DVision Technologies
http://www.scottjbaugh.com
Merry Christmas
Same people answered in the same order, until I posted this.
Scott Baugh, CSWP
Perhaps you should post another reply in the other one to keep it matching.
automationbabe (Mechanical)
If you have SW2004, you can purchase PAC4SWX and batch save as pdf or batch print to pdf. It doesn't cost much and it has saved me tons of time and money.
drawoh (Mechanical)
joshposh,
cninneman (Industrial)
I have used pdfFactory with good success. It is setup as an added printer, just select it when you print a document. It'll open up a seperate program window, and then you can save the pdf file, or print to it again, to add more pages. You can even mix in different programs, for example print a word or excel document and then a solidworks drawing as a second or third page. They have a free trial version for download, it adds a "trial version" stamp to each page. I think it's a pretty slick little program.
Merry Christmas
Hmmmm .... then of course I would have to repost there too to match this & then ......
nahhhh .... It's nearly 4:30 ... I'm going home.
http://swtools.cad.de/us_prog_pac.htm
Or develop your own API
Hope it helps
If you have a PostScript printer, look into GhostScript. Most and possibly all laser printers are PostScript. GhostScript is Free Software orignally written on UNIX to convert PostScript to whatever the printer understands. PostScript on a nine-pin dot matrix? Wheee!
It converts to PDF. The GUI extension to GhostScript is called GhostView, and it is available for Windows.
Select print. Select your PostScript printer. Select Print to file. Change the filename to something with a .ps or.eps extension. Print. Load the PostScript file into GhostView. Select convert, and select pdfwrite.
The latest version of Windows GhostView is nagware. Earler versions are not, and they work fine.
This is not absolutely convenient, but it gets the job done.
JHG
http://www.pdffactory.com/
Hope that can be of help to someone.
Later
Chris
