transistor equals temperature
Hello:
I am trying to get a general purpose transistor e.g. 2n4124,CA3046, or 2n2222, to yield 1 degree accuracy of the enviromental air temp. Using a delta Vbe, My Eq. is: T=(q(Vbe1-Vbe2))/(K(LN(Ic1/Ic2)). The circuit plus Eq. yields roughly 40 deg. at room temp 22 deg. Am I missing something that the highly predictable results of a transistor can give. Yes I know there are predeigned IC for this application; However, I would like to use a GP transistor.
thanks a bunch, too hot
RE: transistor equals temperature
low enough current, so the series resistances don't cause significant error.
I don't understand the 40....22 ???
If you use conputer interface, the computer can take care of the calibration factors, too.
<nbucska@pcperipherals.com>
Cordially;
Xray
There are plug-in breadboards for PC with interface
Look up www.maxim-ic.com or linear, dallassemi etc
how they do it. and their AP notes.
Any help is appreciated.
S/H leakage, offset etc. error, non-linearity ?
A silcon junction as the base to emitter in a bipolar transistor is a good choice as a temperature sense element.
It has good liniarity from -55 to about +150C. With a current of about 1 mA, it changes about 2.2 mV per deg C, with the voltage drop decreasing as temperature increases. Calibrate with ice water for 0 deg C, and boiling water for 100 deg C (assuming you are close to sea level). This method of temperature measurement is commonly used in many systems because of its simple accurate and inexpensive approach.
Elecmec
John Markus, "Electronic Circuits Manual," McGraw-Hill Book Company, 1971
Substrate Temperature Control on page 833
