how to change tracking set up in UNX
When drawing in Unigraphics,(a line for example) the first
entry (first point) can be entered in X & Y format but for the second point I have to enter length and angle, can I set up the system so that I can continue with X & Y? Thanks
RE: how to change tracking set up in UNX
After you enter the start point, enter another X and Y for the end point. Also, you can use the delta option to get delta offsets from the start point.
Are you reffering to nx2 or nx3 ?
Thanks Cowski, I never noticed that delta option. Just when you think you know most of what the software offeres, you find something new in the simplest of commands.
Keith Young
keith.a.young@comcast.net
Walway Enterprises
UG Tool Design
