DIN Machining Tolerances
Does anyone have any info relating to General machining tolerances to DIN standards. Whether you can point me to the right standard # or simply just share your knowledge????
I have a meterbody I need to machine but alot of the features on this body that are machined are not toleranced...they have dimensions...just no tolerances.
Thank you
RE: DIN Machining Tolerances
ISO 2768 is one standard you might look to.
But it wouldn't apply unless called out on the drawing...is there a spec. called out on the print, or a block or not defining general tolerances?
