quad elements posing as triangles
It's well known that 2D linear triangular elements are useless for stress analysis. If a model is meshed with triangular shaped elements but these elements are in fact quadrilateral elements with 2 nodes the same, ie. node numbers 1-2-3-3, will the reults obtained be just as useless?
corus
RE: quad elements posing as triangles
The results will be even more useless (if that's possible), triangles and quadrilaterals use different shape functions, thus a quad with a degenerate side is not the same as a triangle element, at least the linear triangle will generate some form of results, whilst the quad (if the solver doesn't kick it out) will produce rubbish.
Do you talk about the fact that there is no continuity of the second derivatives , i.e., the stress field for linear triangular element, plus some stresses that cannot been accessed, despite mesh refinement ?
I am sorry for this late reply & I hope your question is answered, but when this has occured in any of my analysis an element check will locate these elements &/or the analysis will fail with a message hinting (solver messages are never direct) the problem. I use FEMAP & CAEFEM currently, but NASTRAN & Patran have also notified me of these conditions.
JXC
