Tubing for dry sump
Tubing for dry sump
Amigos,
I'm slowly putting together a dry sump system for my straight six racer. I've a couple of questions for the more experienced...
Can you recommend a 5/8" tubing that can be bent in the home shop and terminated in the AN format. I'm thinking I don't need the expensive braided lines the whole way.
Second question,
I thought I read here about a pan builder that would work with you, first requiring your stock pan to build from. I can't find it in the archives, does anyone else remember that thread?
Second question,
RE: Tubing for dry sump
pat pprimmer@acay.com.au
Good Luck with your project!
www.pegasusracing.com
Tube Sleeve, AN (AN 819) Part # 3236-10 $1.99 each.
Rod
