Piled foundation fitness for service
Hello all!
Does anyone know a fitness for service plan for piled tank foundations under a storage tank?
API 653 appendix B addresses settlement of tanks on soil, or on a ring wall. It does not cover a tank on a concrete pad supported by friction timber piles. We can measure the edge settlement around the tank. But the settlement pattern of a piled foundation tank must be different from a tank on soil. Aside from checking the appearance of the concrete for defects, are there other ways? I am concerned that following API 653 appendix B may not be sufficient.
Please note that I have sufficient info on designing a piled foundation. The inquiry is how one can tell whether an existing piled foundation is OK for continued service. In some situation, the pile log info is not longer available. This means the pile capacity and the pile quantity are not known.
RE: Piled foundation fitness for service
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Thank you very much for your insight. You confirmed what I know up to this point. API documents do not address FFS for concrete foundation on piles.
This is what I found from literature (caution: not from field experience): Timber piles last indefinitely under water. It can be attacked by insert, fungus, etc. if above the water. Treating piles with creosol extends the life. There are other reasons that timber pile foundations can fail - negative skin friction, group settlement, lateral load, excessive load, soil erosion, soil liquefaction, seismic event, pile buckling, etc. This is why geotechnical engineers use a safety factor of 2.5 to 3. (Moot if piles disintegrate under the foundation.) Problem with pile foundation is that once it is built, it is not easy to tell if it is OK afterwards. Having engineering drawings, pile driving record and soil boring report helps. Without them make it even more challenging for a foundation FFS evaluation.
Even with the uncertainties mentioned, I shall appreciate insights on what can be done to determine if a pile foundation is OK.
Ultrazero
I don't believe that the wet-dry issue was present on the three failures I am familiar with. The piles temps were just too high for the wood to sustain.
Steve Braune
1. Start with an empty tank and measure numerous, specific top of foundation perimeter elevations.
2. Fill the tank in discrete stages (with water or product), recording the foundation elevations at each stage.
3. Empty the tank in stages, again recording the elevations at each stage.
4. At the perimeter location with the worst differential settlement/ rebound characteristics excavate a pit, down to the water table if possible. Inspect/core a pile(s) to get an idea of status.
Unless you have conditions like those described by SteveBraune, the worst deterioration most likely will have happened at or near the top of the water table. Wet/dry cycling is typically the worst environment for timber, even treated (creosoted) timber.
Would you mind to quantity your answer? Say, formula, specific settlement value, or rebound value, as the criteria for acceptance or rejection?
Ultrazero
Pile load tests are covered by ASTM D1143. However what you have described go beyond the scope of a "normal" test - I doubt if you will find ANY exact criteria to apply to the situation. This is one of those cases where "engineering judgement" will most likely be needed to make a detemination of the foundation's acceptability. You may need to contact a qualified engineering consultant to get the specific level of experience needed.
I am getting a handle on this. We are contacting an expert for a further evaluation.
Ultrazero
