Change the text of a hole table in 2005
Well, Here I go again. I don't know if there is just me, or there is a lot of "bugs"? or things missed in SW2005...
Ok, I need to change the text of the size column in a hole table, but I noticed that I can add some variables, delete some others, but not all. I want to leave only the thread indication in the table, but SW always put the tap drill diameter. This is one of the variables I CAN'T DELETE, (by the way, it is showed in lower case letters). Any Idea?
Thank You
Thank You
Adi Corrales Magallanes
Centro de Ingenieria y Desarrollo Industrial
Queretaro, Mexico
RE: Change the text of a hole table in 2005
Whether or not that effects the Hole table I can't be sure. Contact your VAR and have them ask SW.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
