Assembly mating?
Assembly mating?
Assembly mating?
Does anyone know how to get a part to follow a path with multiple radi?  I can make one part tangent to a section on another part but it will only follow that radius when dragging.  How can I get the part to follow the path if it has several bends and curves?  Can it be done?
RE: Assembly mating?
Look in SW Help for Cam Mates.  Also, try visiting this site, you can download files and "reverse engineer" some of his things.
http://www.mikejwilson.com/solidworks/solidworks_files.htm
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I tried the composite curve, no luck.
